Rear brake lights ?common problems
Mikeinjersey
hello all dogs,no rear brake light,other than the caliber swathe what else should I change
What Bike do you have? Do your Blinkers/emergency flashers work? Does it fail with both front brake and rear brake? Remove the seat and look for any broken wires to the rear fender area. Also, depending on which EHC you have you may have a fault indicator led lite to help isolate your issue.
Tacoma2017
Thanks for reply,Front brakes stopped working last year this week the rear brake stopped working I have a 2005 bulldog all the wires look good trace them all out I’m gonna try changing the caliber sensor do I have to change the EHC module if the sensor doesn’t do the trick
Tacoma2017
Flashes and blinkers work
Mikeinjersey
Hi Tacoma, Since your lights work my guess is it's not the wiring to the lamps. Disconnect the battery negative side first then Positive. Then I would pull and reset the connectors on the EHC. fresh Dielectric grease and clean as necessary. Reconnect battery positive side first then negative side. Check the brake lights. If you still have the problem use the link up top to help you troubleshoot the front and rear brake switches. I hope this helps Good Luck. Let us know how you make out.
Tacoma2017
Tacoma2017
Hey Mike how are you it’s Glenn I change the brake light switch took out the battery receded the main back bone wire harness and now I have nothing replaced main fuse are there any other fuses that you know of could it be a blown module
