Mastiff Rider64
Ok guys, I need your advice or help on something. My 2009 Bulldog Bagger seems to be running extremely hot. So hot that after the ride I planned the other weekend I may need someone who can paint the Anniversary paint job on the electrical side covers. During my ride the other weekend the bike ran very well, but it seemed to running extremely hot. When we left out that morning temps were mid 70's, when we got to Barbarosa Saloon in Tenn they were mid 80's, Gatlinburg was about 92 when we got there, and the heat coming off the bike in the stop and go traffic made me decide to park the bike and visit while the bike was cooling off.
The day before leaving I noticed my transmission fluid was low so i added some till the full make with bike standing up right, did an oil change also added the correct amount of oil then ran the bike to let it get thru the system and added some more to the full line after it went thru the new oil coolers I used 20w-50 amsoil synthetic, added my oil pressure gauge, which I'm a little confused, after starting bike I'm running like 30 psi at idle, as the motor warms up it does lower down to about 10 psi. But I have theory on why in Gatlinburg it was at 0 psi at idle and the little bit of moving or throttling up it only moved to like 5 psi.
But after parking the bike, I pulled the key out of ignition and the rubber part of key was so soft and mushy, not only did it burn my thumb and side of index finger from grabbing it to remove it, but I dropped it in my other hand and the metal part of it was so hot that it burnt me also to the point I dropped the key on the ground. After 2.5 hours in Gatlinburg we headed back to the bike and rode from gatlinburg all the way to Spartanburg stopping 1 time for gas and stretch our legs bike ran great, even the temp seemed a little better or maybe the fact I was sunburnt I didn't notice the heat on my legs as much as my arms? But we made it home. The next day I go to clean the bike up and i noticed that my electrical side covers paint was bubbling and the plastic was missed shaped behind the rear cylinder. Now I measured the distance of the pipe to the cover removed the pipes put the factory pipes back on and measured and honestly there is no more than an .25 inch difference in the distance so i dont think its the pipes that done it. I think either the transmission got so hot or the motor got so hot that while the bike was parked the heat off of them did this.
Here is where I need your advice or help, whats causing this bike to run so hot?
now here is what I do know, I have the fiberglass washers between the igintion cover and the heads, so heat shouldn't transfer that bad
New spark plugs, new dual oil coolers, wires, oil change, transmission topped off, oil pressure is good except at high temps
never went over 76 MPH, never under 35 unless at stop light, or stuck in traffic in gatlinburg
exhaust was changed from factory with mean mother slip ons to Paul yaffie Phantom II for baggers baffle is still installed
New fuel pump, injectors, throttle position sensor, MAF sensor, rsd air cleaner, running 93 ethanol free gas
![254987[1].jpeg 254987[1].jpeg](https://www.bigdogbiker.com/data/attachments/71/71504-c12c7e586cd0d76741abf69387df3104.jpg)
![254988[1].jpeg 254988[1].jpeg](https://www.bigdogbiker.com/data/attachments/71/71505-d93801b02ec6f7344432184f8b6ede40.jpg)
![254989[1].jpeg 254989[1].jpeg](https://www.bigdogbiker.com/data/attachments/71/71506-17a37bb8db1476e47bb7ac469155848d.jpg)
