Michael rogers
My speedometer goes crazy every once in a while
Sent from my SM-N960U using Tapatalk
RidingWhile u riding or startup
start by pulling the sensor out of the top of the trans and clean it.
Thank you ill look in to itIf you have the original big dog speedo, they were known for the wires inside coming unsoldered and it would cause erratic operation or stop working depending on when they made contact or didn't, I agree with the speedo sensor cleaning first but if that doesn't work this is another thing you can try but unfortunately you do have to take apart the entire speedo to find out or at least get to where the wires are to see if they're connected or not which means taking the whole Speedo apart there should be or used to be HOW TO on this site for this because it was so common
If you have the original speedo and cleaning the sender doesn't work, my personal vote would be it's the perfect time to convert to a dakota digital speedo.If you have the original big dog speedo, they were known for the wires inside coming unsoldered and it would cause erratic operation or stop working depending on when they made contact or didn't, I agree with the speedo sensor cleaning first but if that doesn't work this is another thing you can try but unfortunately you do have to take apart the entire speedo to find out or at least get to where the wires are to see if they're connected or not which means taking the whole Speedo apart there should be or used to be HOW TO on this site for this because it was so common
I am thinking about converting myself. Any suggestions?If you have the original speedo and cleaning the sender doesn't work, my personal vote would be it's the perfect time to convert to a dakota digital speedo.
Posted the following on your other thread "Speedometer Replacement"I am thinking about converting myself. Any suggestions?
Is this a plug and play item? My tach has always flashed and no matter how fast the motor turns, only 2 green bars show after reaching a decent speed. Speedo works but the tach is shitIf you have the original speedo and cleaning the sender doesn't work, my personal vote would be it's the perfect time to convert to a dakota digital speedo.
The Dakota Digital is awesome. I just changed to it last week. HOWEVER, this is a speedometer ONLY replacement. The original tach is NOT replaced with this item.Is this a plug and play item? My tach has always flashed and no matter how fast the motor turns, only 2 green bars show after reaching a decent speed. Speedo works but the tach is shit
Mine started to blink, then all the green and red lights turned on. Any idea what’s going on?My speedometer goes crazy every once in a while
When I had the speedo can open doing the Dakota Digital Speedometer install I found a bit of corrosion on the tach board. I cleaned that up with some rubbing alcohol and applied some dielectric grease to it to help protect it from further moisture. Havent seemed to have a prob since.Mine started to blink, then all the green and red lights turned on. Any idea what’s going on?
Nothing "wrong" per-say. Thats from idling too low.Mine started to blink, then all the green and red lights turned on. Any idea what’s going on?
