LED Headlight with bucket
BADOG
Would like some recommendations for an LED headlight with bucket which would be a plug and play by simply swapping out what I have now.
TIA
No that's a 7" that would be really big on a dog you need a 5-3/4.
If your headlight housing is in good shape just get the sunpie 5-3/4" on Amazon and take out your lense and plug this one in and off you go. Only about $40
BADOG
Thanks, unfortunately the bucket doesn't come apart but I found this bucket with H bulb and lens on Amazon.
Just don't know if it's plug and play.
Jersey Big Mike
100K mile club
The bucket will come apart -- it might be a pain in the ass but it will.
If its a stock bucket the 2 stupid set screws on the bottom might strip out if not careful.
My first K-9 I drilled out the set screw and kept the beauty ring installed with a little clear silicone.
Clubba
TIA
I used the stock bucket but replace the headlight with a Hog Lightz unit and I love it. It works awesome!
Clubba
Big Dog makes a special tool for removing the headlight ring. It has three prongs in a triangle configuration with a square adapter in the center that your 3/8 ratchet extension will fit in. Just don’t forget to remove the setscrew at the bottom.
Jersey Big Mike
100K mile club
Almost built one of them years ago (my own design) but I figured I'd never spend that much time inside the HL bucket.
I can count on my finger the number of times I've had to fight with those rings and now that I got rid of the stock bucket never again will it be a problem on my bike.
The headwinds is much easier especially when you're on the road and a bulb goes out.
Clubba
That’s the truth! Headwinds makes some great products.
