mleach72
Believe it or not, you are probably running lean at idle after fixing the leak. This is what happened when I had a manifold leak. After fixing the leak, I figured I would have to lean the mixture because the motor is getting less air. The opposite was true. Fixing the leak caused a greater vacuum through carb. The motor was now getting more air. I had to richen the idle. This would explain your rpms dropping.I only adjusted the idle speed since, after the hose removal, the low idle was making the tachometer flash red and yellow until i opened the throttle a tad.
How should I adjust the gold "+" idle mixture?
Now that you have removed the vacuum from the motor, both lines are now acting like regular breather lines. If you are going to run it that way, I would suggest getting longer hoses and running them to the ground. Without the vacuum from the manifold, they may spit oil on you motor and carb.
