Oh and I'm working on an 08 k9.Got a fork seal rebuild kit and taking everything apart got to the point of taking out the damper tube bolts out and they came loose but there just spinning loose but will not come out. It's like whatever there bolted to is spinning also any ideas?
When re-installing be sure to use the new copper washers...Ok thanks brother! I'll try anything at this point.
He's talking about removing the cap screw, not installing. Impact is the tool for the job, prolly even says it in the manual...An impact won’t help in your situation, lift up on the lower leg until it hits the damper then you’ll be able to get the bolt started. This happened on mine as well not really that big of a deal. I hope this helps you.
Damnit my mistake I guess I didn’t read thoroughly enough lolHe's talking about removing the cap screw, not installing. Impact is the tool for the job, prolly even says it in the manual...
Yep, yep it does..
All good Freddie.Damnit my mistake I guess I didn’t read thoroughly enough lol
Yes sir that's what I ended up doing and it worked thanks for all the help!Sometimes if you leave the springs in they exert enough pressure to prevent the dampner from spinning. Then remove the springs.
John
I ended up putting the spring and spacer back in and that put enough pressure on it to allow me to get it out. Thanks for all the help guys.An impact won’t help in your situation, lift up on the lower leg until it hits the damper then you’ll be able to get the bolt started. This happened on mine as well not really that big of a deal. I hope this helps you.
I never needed an impact just have always removed that bolt first. I just remove them and go have a beer while they drain. Then start taking them off.I ended up putting the spring and spacer back in and that put enough pressure on it to allow me to get it out. Thanks for all the help guys.
Yeah that's what I'll do next time, learned the hard way but good learning experience! And the beer is great advice also definitely be doing that! Thanks brother.I never needed an impact just have always removed that bolt first. I just remove them and go have a beer while they drain. Then start taking them off.
