I purchased my 05 chopper brand new from Dorschele a big dog Harley and iron horse dealer in Rochester NY, when I tookI work with Electronik, Axel, because they are an excellent manufacturer and provide excellent warranty and customer service when issues arise. I have yet to have an issue when a warranty replacement was needed.
I have years of experience with Big Dog motorcycles and I can say with absolute certainty that a vast majority of the BDs have, have had, will have, take your pick, burned out or damaged electronic components and in some cases can't keep a battery in the bike for any real period of time without it getting damaged due to a poor choice in charging system selection by BD. So much so that the first thing we do with any new local customer is yank the stock charging system. In every case the damaged component issue went away. There are times when the cumulative damage from the OEM VR was great enough, in some components, that they still failed but there isn't anything one can do about that. There have been many other reasons for some of the damage but a huge portion of it was due to the OEM VR.
I too purchased my 2006 K9 new and have 33,000+ miles on mine. I have done all of the recalls also. I would assume most owners performed the recalls when they came up? The one in question is captured below:I purchased my 05 chopper brand new from Dorschele a big dog Harley and iron horse dealer in Rochester NY, when I took
Mine in for the recall they never mentioned the charging system being bad just the possibility of a failing circuit breaker in the case if the voltage regulator shorted out. The dealer installed a fuse link in place of the circuit breaker and I’ve had no issues with the stock regulator nor the stator and I’m approaching 37,000 miles. I’m fairly certain I kept the recall notice and repair order of more info is needed on this topic I’ll be glad to share it with the forum https://images.app.goo.gl/fooxeVaoe2sC1Pzf9
| Corrective action | DEALERS WILL REPLACE THE EXISTING CIRCUIT BREAKER LOCATED BETWEEN THE VOLTAGE REGULATOR POSITIVE BATTERY LEAD (B+ LEAD) AND THE POSITIVE BATTERY TERMINAL WITH AN ALTERNATIVE CIRCUIT PROTECTION DEVICE THAT WILL PREVENT A THERMAL EVENT IF THERE IS A SHORT TO GROUND. THE RECALL BEGAN ON OCTOBER 1, 2007. OWNERS MAY CONTACT BIG DOG AT 1-316-219-9129 OR EMAIL TO CUSTOMER.SERVICE@BIGDOGMOTORCYCLES.COM. |
| BIG DOG BIG DOG - (1 Recalls) | BIG DOG HUSKY - (1 Recalls) |
| BIG DOG BOXER - (6 Recalls) | BIG DOG K-9 - (7 Recalls) |
| BIG DOG BULLDOG - (16 Recalls) | BIG DOG MASTIFF - (23 Recalls) |
| BIG DOG CHOPPER - (23 Recalls) | BIG DOG MOTORCYCLE - (2 Recalls) |
| BIG DOG CHOPPER - DT - (1 Recalls) | BIG DOG MUTT - (1 Recalls) |
| BIG DOG CHOPPER DT - (4 Recalls) | BIG DOG N-CHOPPER - (1 Recalls) |
| BIG DOG DAYTEC CHOPPER - (2 Recalls) | BIG DOG PITBULL - (15 Recalls) |
| BIG DOG DT CHOPPER - (1 Recalls) | BIG DOG RIDGEBACK - (14 Recalls) |
Axel/Curtis, Are you guys suggesting all BD owners replace their stock(OEM) VR or just specific years/models?
I think we should all be cognizant that these bikes are now at almost minimum 10 years old. A VR and stator will eventually wear out, and I think while people are working on their bikes it just makes sense to replace your 10+ year old part regardless of issues. It's just cheap insurance to do now, especially as these bikes have changed hands many times, and entire new system will only cost you about $300.Hi Kobi and pknowles,
I had here in Germany about 6 - 8 times a customer with charger problems within the last 2 years. I know it sounds not much but we have not so many Big Dog bikes here. I´ll look for my old memories and try to find out what bikes had the problems or try to reach the customers. I don´t know if it was a problem with all OEM regulators within 2004 and 2011 or only within a small time period. I think it would be fine if everybody who had (overvoltage) issues with his charging system can send a short message and we can make a small table with the models and years and post it here. Maybe it´s good for a new thread? What is your opinion?
All the best!
Axel
According to to the recall it was only 2005 and some 2006 that had the charging system issue , my recall was done at the dealer. Early on BD thought it was the VR but still had issues on the recalled motorcycles after replacing the VR and found it to be the circuit breaker was the culprit so they revised the recall and started putting in 40 amp fuses in place of the circuit breaker. I believe that the major flaw was not fuse protecting the ehc directly from the battery which would for sure cause ehc destruction under a voltage spike so along with the 40 amp fuse the protect the battery from a voltage spike and an in-line fuse from the battery to the ehc will protect the ehc as well as all other electrical components on the motorcycle. Changing the charging system is completely unnecessary as Im sure there are more BDMs out there running the stock system than not. Look up Big Dog specs on current models they are still using the 32 amp system as is Harley Davidson along with most of if not all other motorcycle manufacturers, if that was an issue I would think the late model/current Big Dogs as well as other manufacturers would too be burning up electrical components.Hi 1 B.M.F,
Thanks for your comment. It´s nice to read.
All the best!
Axel
First off a person must really understand exactly what is happening with the Phelon, I think I'm spelling that right, Voltage Regulator to talk about whether it's safe or not. Reading recalls, owning one or two Big Dogs even "working on bikes for forty years" doesn't qualify a person to give BD owner's advice on whether they should replace the OEM BD voltage regulator or not. While it's true that many of the BDs have not had this issue many have. Any bike that has suffered a component melt down needs a serious looking at and likely a VR replacement. With the alarmingly high number of BDs that have had component failures, albeit not all from the OEM charging system as many have done things to their BDs that have caused electrical failures, any BD owner should take a serious look at whether they should get rid of the OEM charging system or not. Speaking from a position of actual heavy experience with the OEM charging system, both servicing and investigating, we recommend that they be changed before they have a chance to cause failures. Of course if you have 50,000 miles on your BD and have never had any issues then it's not likely you need to change the VR but then again it is still the same VR by the same company that has had numerous issues so maybe........According to to the recall it was only 2005 and some 2006 that had the charging system issue , my recall was done at the dealer. Early on BD thought it was the VR but still had issues on the recalled motorcycles after replacing the VR and found it to be the circuit breaker was the culprit so they revised the recall and started putting in 40 amp fuses in place of the circuit breaker. I believe that the major flaw was not fuse protecting the ehc directly from the battery which would for sure cause ehc destruction under a voltage spike so along with the 40 amp fuse the protect the battery from a voltage spike and an in-line fuse from the battery to the ehc will protect the ehc as well as all other electrical components on the motorcycle. Changing the charging system is completely unnecessary as Im sure there are more BDMs out there running the stock system than not. Look up Big Dog specs on current models they are still using the 32 amp system as is Harley Davidson along with most of if not all other motorcycle manufacturers, if that was an issue I would think the late model/current Big Dogs as well as other manufacturers would too be burning up electrical components.
Here it is right on Big Dog is back website , specs showing 32 ampFirst off a person must really understand exactly what is happening with the Phelon, I think I'm spelling that right, Voltage Regulator to talk about whether it's safe or not. Reading recalls, owning one or two Big Dogs even "working on bikes for forty years" doesn't qualify a person to give BD owner's advice on whether they should replace the OEM BD voltage regulator or not. While it's true that many of the BDs have not had this issue many have. Any bike that has suffered a component melt down needs a serious looking at and likely a VR replacement. With the alarmingly high number of BDs that have had component failures, albeit not all from the OEM charging system as many have done things to their BDs that have caused electrical failures, any BD owner should take a serious look at whether they should get rid of the OEM charging system or not. Speaking from a position of actual heavy experience with the OEM charging system, both servicing and investigating, we recommend that they be changed before they have a chance to cause failures. Of course if you have 50,000 miles on your BD and have never had any issues then it's not likely you need to change the VR but then again it is still the same VR by the same company that has had numerous issues so maybe........
In addition there are no "current specs on current models" as Big Dog, the real Big Dog, went out of business in 2011. Any bikes being made by other companies now are of their own design and really do not apply to the category of original BDs.
