Very nice
Thanks for the update and great work
Axel
Sent from my Life One X3 using Tapatalk
Axel
This is good news Curtis...I just sent you an email asking about mine...lolOur first shipment is arriving today folks.
The 58c will work in your 2010 bagger but you will need to send the OEM EHC to us so we can swap the d-sub shells from the OEM to the new module.
If yours is a carb bike this one should work. I would call first. WildsteedworxI have a stock never modified 05 chopper what version do I need..thanks
I will do.Don't hook it up. Bad idea. I had a meeting at the factory a while back, LEDs and neon lights were discussed. The frequency that neon puts out will mess with the ignition system. And tying into your wiring system, when putting LEDs in could overload your EHC.
That being said, I don't know about Axle unit, and hooking up that wire. Ask the Kaptin when you talk to him.
Thank you so much. It makes sense as to why i guess with my factory ECH I could never get this function to work on the LED controller for my aftermarket LED's.Hi Mastiff Rider64,
Thanks for the question. It shouldn´t be a problem with the new box to change the rear light function from US mode to European mode. In this case is the tail light dimmed to 30 % if no brake switch is activated and it light up to 100 % when you brake. So, you can wire your center brake light together with one of the red cables what go to the tail lights and use the tail lights as brake lights as well. However, it´s made for the European market. We often use the same high brightness led inserts for the tail light function and brake light function as well and have the direction indicators separated from the brake lights. You just need to change the program option 3 in the manual from US mode to European mode. The new EHC have the US mode activated by default. So, you might need to change it to the EU mode if you use other led´s. I attach the manual.
By the way, I had send the following led boards to Curtis a while ago: http://elektronikbox.de/bdled_uk.html . I made the boards for my Ridgeback more than one year ago, cause I was not very happy with the brightness of the original rear light boards at this time.
All the best!
Axel
