Titan Lift Table
Viking
Biker
Those works on the bagger, but not on the K-9. Not that it is a big problem to get it under but I gotta lift the wheel up first while its on the table. With a removable plate under the rear wheel it takes no time at all, but one that would fit would be better...
Please, what is the make and model of this lift. Own 2 lifts and neither one will fit under my 2007 K9.
Assume your talking about the lift I have that slides under the bike with my garbage on top and not the table lift? Haha
OTC Motorcycle Lift 1545
But whatever one you got just roll the bike onto a few 1/2" pieces of plywood or something, don't waste the money if you already got two!
Pete F
Unfortunately my one lift is dedicated to my Indian Roadmaster, has Indian specific adapters bolted to it. My other lift was for my old Honda Valyrie. I do not have the room in the garage with cars and Indian to lay out plywood for the K9. Selling the old jack and will get a new one. Your OTC 1545 is unavailable. Found one similar...Titan MPJ-1500 that has a low profile of 2 3/4" and lifts to a height of 16". Thinking of giving this one a try. Thanks for your help!
Tim
Founder
Lifetime Supporting Member
This is what you want. My lift came with this scissor jack and it fit under my old K-9 with room to spare.
Pete F
Thank you!
  • Like
Reactions: Tim
Moesride
Motorcycle, Vehicle, and Automobile Lifts: Home
This is the setup I have. Perfect fit for the K9. I'm using the Conder chock in front so once I'm on the table the bike stands on it's own.
This setup has casters on all four points of the lift which makes it really easy to move around.
I also use a scissor lift that slides perfectly under the frame.
So I lift the bike just a bit and take the pin out of the condor cradle and Bam, front wheel is free and moves perfectly from side to side.
Had this fir a bit and really diggin it.15691019182038614104048170516305.jpgView attachment 678991569101886544304181458801437534.jpg15691018414728306992586357403775.jpg
