Yes, there are several mounting options for the front wheel wise, one of them making it perfect for the K-9.Already posted my other comments in the other thread.
I like this one. Lift height is 40" fully extended that is plenty good.
Only question I have is will k9 fit? Without modification? Says table is 102" with their extension. K9 is 108" heel to toe.
Bought it in Daytona during Bikeweek. $920,- delivered inside my garage. Shipping is what kills the good deals, but for me it ain't worth it to go to some terminal, spend half a day, and then drag it home myself. No hassle delivery for $230,- was an investment well worth it to us. We spent the day at the range while he delivered it and had it up and mounted in no time. The lift is the best I've seen and I have been looking for a while... Get one during Biketoberfest.Where did you get it I'm thinking I'll get one soon
Yep table lifts are great. You don't know how good they are till ya get one. Then you wonder how you survived with the other smaller lift.The K-9 was a perfect fit too, in case some of ya wondered. A few tricks was even learned to have it so high that the scissor lift could fit underneath it. Best investment I've done in a while for sure....
I bought a scissor jack to use on top of the table. It works great for front or rear wheel work. And yes, the table is awesome, don't think my K-9 has ever been this clean. I drive either bike right on and with the K-9 I put a 2x4 under the rear wheel so as to get the scissor jack under it. Works great and I can do it all single handed.Yep table lifts are great. You don't know how good they are till ya get one. Then you wonder how you survived with the other smaller lift.
It takes a little extra time to get the bike on a lift and setup for wheel changes and whatnot since you need to lift it off the platform with two more jacks but the extra time it takes to do that setup saves you time in the long run from not be all bent over.
I've only found one thing wrong with a table lift...you can't bleed the front brake because the handle bars need to be turned to get the resovoir flat.I bought a scissor jack to use on top of the table. It works great for front or rear wheel work. And yes, the table is awesome, don't think my K-9 has ever been this clean. I drive either bike right on and with the K-9 I put a 2x4 under the rear wheel so as to get the scissor jack under it. Works great and I can do it all single handed.
I use mine to hold my garbage pail...As low as 2 3/4 and as high as 16 3/4
Haha...im actually using them right now. I get plenty of gym timeIf you was to start using your weights a little more you wouldn't need to Jack up the garbage can to get it to the curb
Nice. Ever seen a table top scissor jack that can make it under the K-9?I got my Titan jack yesterday and was able to use it today it sure is nice have a jack low enough it goes right under the bike no messing around with wood or ramps to get the frame up higher
https://jmcautomotiveequipment.com/...PMrP8-yF4qrP1RX8uoza2d8XR4-fItdyNwaAjnq8P8HAQ
