Oil leaking from this line. What does this line do?
wayne64li
107 cc S&S 2003 Big Dog Chopper
This braided line comes from the bottom of the motor. Then connects to the billet connector. Then the rubber hose just zip ties to the frame.
1. What is this line for
2. What does the billet coupler due if any thing.
I get oil dripping out of the rubber end. Should it be capped.
Oil leaking from that line is expected it's your bottom crank breather.
I have never seen a check valve on one however. I thought that bottom breather should go both ways if you do open it up and not restricted. Suck and Blow!
wayne64li
Thanks for the help everyone. Didnt start my bike in a while. Took off the check valve. Cleaned it up and no more leak. 1st night out with her I got caught in a downpour. All good
Mr Wright I see what your saying. Im going to look into that further.
Rottweiler
The longer the bike sits the more oil will come out of it, the first time you start it.
Big dog papa
I came across this old post and because I have a 2003 chopper, I wanted to show you how my bike is set up. Got the bike like this. Don't know if it's stock but it work fine until I push it hard then I'll get oil out the head breather.
That is quite the set up. And dear I say ugly. Sorry. If it was me, I would replace the air cleaner with one that has a vent bracket that bolts to the heads. ( See picture) Then you can plug off the one down on the crank case. HDM has them in stock, for a good price. It won't look like mine, and you can point it forward.
Big dog papa
Nice clean look.Thx for the post.
