Clutch adjusted correctly ?So I just changed the plates and carrier as well as inner and outer hub. Bike on bench runs perfect switches gears better then ever! However on the ground in gear it doesn’t want to move at all. What did I miss?
With wheel off the ground and bike isn't running you can change gears without clutch and will be smooth. Same with it on the groundWhen the bike is on the bench with the wheel off the ground it changes gears perfectly the clutch engages and disengages with out a problem. On the ground the bike goes in gear fine, however when you let off the clutch it doesn’t disengage and has no forward movement.
