Crank Position Sensors (CKP)
• This sensor provides input signals that indicate engine rpm.
Flywheels have 32 teeth with 2 missing teeth. These missing teeth give the
reference for engine timing.
Camshaft Position Sensor (CMP)
• This sensor provides input signals to indicate what stroke the engine is in. The
sensor is located inside the cam cover. The rotor is driven off of the camshaft (on an Evolution
engine) or the rear camshaft sprocket (on a Twin Cam engine).
The Cam Sensor is a Hall-effect device mounted on the Cam Sensor Plate. It is used in conjunction with a rotor 'cup' mounted to the end of the camshaft. As the cup rotates, it passes through the Cam Sensor. Slots in the cup walls are 'timed' to the engine, allowing the cam sensor to indicate to the ICM the position of the cam shaft, and therefore, the position of the crankshaft. This information is used to time the firing of the spark plugs.
