It's a 04 bulldog with 107 S&S motor I replaced my ehc in 2017 with the one from AlexAwg is right....could be numerous things like a short on the cam sensor or the cam sensor itself is bad....could be real simple...what year is it and model
U mean axle?....if so thats a good system...like Awg Mr wright and myself said its probably a short near the cam sensor or the cam sensor itself... if its a cam sensor they r only like 60 bucks on ebay....late 70 and early 80s cam sensor will fit it just have to wire it up....3 wires....red black and green....simple simple job if thats the case and i hope it is....keep us posted we all try to help you if we canIt's a 04 bulldog with 107 S&S motor I replaced my ehc in 2017 with the one from Alex
Can you send the link to which one I need to be looking for.U mean axle?....if so thats a good system...like Awg Mr wright and myself said its probably a short near the cam sensor or the cam sensor itself... if its a cam sensor they r only like 60 bucks on ebay....late 70 and early 80s cam sensor will fit it just have to wire it up....3 wires....red black and green....simple simple job if thats the case and i hope it is....keep us posted we all try to help you if we can
Ok will ask abt this today. ThanksThey make a spa1 spa2 spa3....i dont know what the differnece is in these they look the same...figuring they r upgraded version is the reason for the different number....but have them to do the testing first.....im with Th3infamous i dont think ur axle kit is giving u trouble unless there is a short in something....test the bike we will see what is wrong...View attachment 66526
No problem thats what we are all on here forOk will ask abt this today. Thanks
I would get my bike away from the shop right now !It's a 04 bulldog with 107 S&S motor I replaced my ehc in 2017 with the one from Alex
Ok where did you order it from.I agree you ehc is probably good.
I have a 2004 and had to replace the ignition module right hand side, lower round cover.
Sent from my Life One X3 using Tapatalk
Jpcycles I believeOk where did you order it from.
Ok thanksI will try and look it up when I get home.
The ignition modules for the 02 through 04, duel fire are very hard to find now. Two things you can do. You can get with Thunderheart and get a single fire set up for an Indian. It will come as a kit, coil and everything. Or you can go with the Ultima unit, that will fit in your nose cone. Both will work just fine.Ok thanks
