Basic Motorcycle Wiring
BroadBand
Since late 60's
UPDATED INFORMATION 04/02/2017
Very informative, some duplication but there is some good info to be gleaned from it.
Two links for the same information (in case one link goes down).
A Beginners Guide to Motorcycle Wiring
LINK ONE
LINK TWO
How to Build a Wiring Harness
<LINK>
I am having problems with my 2006 pitbul it won't start from the switch on the handle bars . I put a starter button on the starter for now . any help out there ?
Circuit board in the handle bar controls is bad, or might just need cleaning. Pull it apart, you might just find that it came unplugged.
went in cleaned the white plug looked clean . looked around . put it back together and it still clicks .
the clicking sound come from under the gas tank . is there a relay under there ?
That would be your compression releases clicking. Pull the green wire off your solenoid,and check the voltage both before and as you push the start button. Make sure you pust the run botton before the start button.
That is what I thought might be clicking . I put a new starter in. my battery holds a good charge . This has been going on for about year . it might be my computer . I ride the bike . tied of pusing the starter button on starter . I am waiting for Danna to get back to me . might have to go after market wiring kit . Thank you for all your time my brother . ride safe
What ever is wrong with it, I'm sure it's a simple fix. Just need to find it. Broke wire at a plug, or a bad connection somewhere. Rewiring isn't alway the best way to go. Lot more headaches in the long run. Still thinking it's the circuit board. Whats the voltage on the green wire at the solenoid?
there is no green wire or solenoid on big dog starter just the black wire battery wire and grout wire. everything else on this bike work ?? .( Thank you so much brother for your help) . I would love to get this working right
Disconnect the battery, then unplug your EHC and clean the plugs. Then put some fresh dielectric grease on them.
Thanks . I will try that . I put a jump wire to the battery the to the green wire male end on starter and the starter motor works .I put a new end on the green wire same thing clicks . could it be the ECU computer brain ? you are the Man thanks
ok I unplugged Both plugs and cleaned then and blowed off with air put them back on same click . there is a ECU computer on Ebay for $150 should I buy it . its for my bike to see if that work or should I send it to Winchester black to have him check it out ?
