I've also had one of the adjustable slam buttons cause the starter to engage. Adjusting nut backed off going down the road and starter started spinning!Also i would look into putting a slam button on the end of the starter...i do these on all bikes just incase starter button doesnt work or the battery gets too low u can push the plunger in to get it started and get home
Very true...ive adjusted them little to tight before and caused that to happen...back before the slam button i would drill a 1/8 hole in the end of the cover and cared me a piece of stainless tig rod in my wallet to start them...I've also had one of the adjustable slam buttons cause the starter to engage. Adjusting nut backed off going down the road and starter started spinning!
Another potential possibility for this guy as well if he has one of the adjustable slam buttons
I think that starter relay was only on the 03. Haven't seen one on an 02 or 04, unless it was a carry over model04's and older bikes also had a solenoid module that sat on top of the battery. When mine went bad the starter would engage going down the road. It's a little rectangular box. Had three wires coming out of it.
Mr wright is correct...1.8 2.0 and 2.4...look at the cover and match the slam button to itIf you're ordering a slam button, make sure you get the one that fits your solnoid. Their not all the same
That's crazy. Way too much.They have a slam button on Ebay for 130.00
