04 pitbull to ridgeback build
Rottweiler
Not sure if anyone else has had issues with the reed switch connection not staying connected but this is what I did to ensure it doesn’t come off. I used a small piece of heatshrink and slid it over the connector. I carefully , I mean carefully heated up the heat shrink not to put too much heat on the board. I think that should hold ? Anyone else has issues with this ?
Not with that so far. But I have used Heat shrink on other jst plugs.
Well I got both front turn signals to work and the right control to work. Now I have running lights on the rear but the turn signals are not working . I checked the wires and they appear to be in correctly . This shits crazy
Rottweiler
Sorry to hear that. Damn there is only so much going wrong you can handle for one one night.
Time for a beer
Got it figured out ! Because I had to take the jst connector apart originally my wires were off, after reviewing my notes I changed them around and sure enough everything is working.
Love the esc but the wire colors do not match stock and I don’t see anywhere on the schematics where it explains what the esc wire colors mean. It wouldn’t have been an issue if i was only plugging it in to the stock and that’s on me for messing up the wiring
yea, they don't all match stock wiring. Gotta take your time and double check wiring!
BCD6739D-E641-4CB2-96C6-ED33AABB44E7.jpeg AB4DAC51-0300-4DA0-BA85-CD1ABA07F93E.jpeg Update : getting real close..
Headlight installed electrical system all good
Calipers delivered from sport chrome
Waiting on the air cleaner install and wheel alignment and spacers made. Going to do a TDI this weekend to check torque requirements.
Yes those are flowers in my man cave !! The wife is a flourist ..
CB8D918C-8AB9-4FA9-8215-447736F03159.jpeg AB4DAC51-0300-4DA0-BA85-CD1ABA07F93E.jpeg
