Pretty easy,I swapped mine out in one evening. Call Derrick and Donna. Once the controls are on you will have to measure from your new rod connector held in the possum you want it back to the transmission linkage. CallDerrick with that measurement and he will then send you the correct linkage shaft.How hard and what would have to be changed to put on extended Controls on a 06 Mastiff? I'd like to stretch out a bit more.
Obviously its cajun for position!Took me a minute to figure that out...lol...sitting here saying WTF is the Possum, then I got it![]()
Position, sorryPretty easy,I swapped mine out in one evening. Call Derrick and Donna. Once the controls are on you will have to measure from your new rod connector held in the possum you want it back to the transmission linkage. CallDerrick with that measurement and he will then send you the correct linkage shaft.
