Here’s a drop box link to big dog manuals. Lots of good info.Question,
What is the right procedure to start the bike once key is turned on ? Now remember I am a newbie with this...
Should I press Run button and then Start ? Should I press valve release buttons on top of engine before every start ? Thought that works automatically...compression release mechanism I am talking about..
Don’t have a manual ...
I appreciate any info on this ...
thanks for the heads up...I was getting my extra tire out to take to the shop and it had a mfr date of 2011...not comfortable with it even though it looks like new (stored in box out of the sun) got one from 2wheel as you suggested for $279Found them cheaper at 2wheel.com
Yep ! Glad it worked out !!thanks for the heads up...I was getting my extra tire out to take to the shop and it had a mfr date of 2011...not comfortable with it even though it looks like new (stored in box out of the sun) got one from 2wheel as you suggested for $279
That is a sweet look...
I use synthetic oil and dont have any clutch issues, could just need to adjust it. Takes about 10 mins to do. As far as oil leak, could be oil leaking at the starter from primary, mine would drip a little after riding too. Just check around the starter and see if its dripping from it or notSo i got the bike back yesterday afternoon, I was really excited about it, drove it for around 30 min , overall bike did great , but ...
I noticed clutch when standing in 1st gear was still pushing bike forward slightly ...
And when I got to the garage i noticed when I stopped some oil leaks under the bike , not a lot but enough to stain the driveway in a noticeable way ...
Now , called my mechanic and he said that he would grab his trailer and come pick up the bike to check it out Monday.
I was not driving back to the shop with an oil leak ...
After some reading I noticed that if you put the wrong oil filter on it which is a Twin Cam engine , this could happen ...
I will be using K&N 170 C for now seems to be the one most use ...
I don’t know what kind of filter is in the bike now ... will find out tomorrow...
And also if you put Synthetic oil in the Primary clutch will start to slip and act up ....
There was no noticeable leaks on the bike before ( since I bought it a week ago ) and clutch was working fine ...
Could this be the reason for this leak and clutch situation, both unrelated things I guess ...
Any ideas or comments will be greatly appreciated,
And again , thanks in advance for all the help that I have received so far from members of this very valuable forum , to us Big Dog owner’s
Cheers
I saw a video on YouTube I think from Curtis (WSW ) explaining that many folks have issues on the primary using synthetic so he recommended mineral oil 20/50 there ... I will show up at the shop tomorrow morning to find out more about the leak ...I use synthetic oil and dont have any clutch issues, could just need to adjust it. Takes about 10 mins to do. As far as oil leak, could be oil leaking at the starter from primary, mine would drip a little after riding too. Just check around the starter and see if its dripping from it or not
