Ed U. Cator
Higher Ed.
Can someone clear up some confusion for me? Thanks!
#1. My 2006 motor is the 117ci stamped with "Super Stock" on it. I've read online that motor is also referred to as a "Super Sidewinder". Are they one and the same or two different models? S&S webpage doesn't list a Super Stock (or is that another custom spec by BDM?).
#2. Being that my bike is a 2006 Mastiff, I found the service manual online for it labeled as 2005/2006 Mastiff. I also read in another post somewhere on here, that the 2007 Mastiff svc. manual is a better version. Which manual should I go by?
#3. The headlamp assembly is factory original & the lamp is an xtra bright H4 halogen that is quite bright but it emits more of a wide horizontal beam (for both low & hi). The reflector is a smooth=faced type, not the faceted kind. I don't want to buy the $$ LED projection type since I'm not keen on their appearance (despite their excellent functionality). I also realize from experience that the LED lamp modules often do not collimate properly further causing down-road, useful illumination. Any ideas on getting back to a more rounded beam for overall better down-road visibility?
