If you turn the key on, press the "Run" button, press the "Start" button and the bike turns over or the compression releases pull in then the PCB board is functioning correctly.2005 and newer BD. You turn the key on, the ignition module red light glows, you press start, coil gets it's power from the module. So if the module isn't powering up, most likely it's the PCB board?
Good job!Well since I tried all the suggestions and still couldn't get the module to power up, I decided to work on the tag light. When I received the bike the tag light was turned sideways and the wires were disconnected. Or should I say ripped. So I reconnected the light. So I figured I would try it again. Well guess what I now have power to the module! So now everything works.....high low beam......left turn signal! Only thing I can figure the tag light being disconnected didn't complete the ground? I don't know. Now I have to see if it will start. Taking a break from it for now. Will let you know if it runs now or if there are more issues.
Tag circuit was probably grounded out which would cause issues with the Thunderheart module circuitry.Well since I tried all the suggestions and still couldn't get the module to power up, I decided to work on the tag light. When I received the bike the tag light was turned sideways and the wires were disconnected. Or should I say ripped. So I reconnected the light. So I figured I would try it again. Well guess what I now have power to the module! So now everything works.....high low beam......left turn signal! Only thing I can figure the tag light being disconnected didn't complete the ground? I don't know. Now I have to see if it will start. Taking a break from it for now. Will let you know if it runs now or if there are more issues.
