hahahahahha excellent
Well that shoots some holes in my theory...I have an open primary
How were you able to access the back of the button to install the tape padding/shimming?Start button wore out on handlebar. Mine did exactly what you are describing (catching as you say) I shimmed the back of the button with some electrical tape and now when hand gets close its starts spinning. It knows what I want
Just took apart the controls and behind the buttons cut some electrical tape to fill in button slots. Think I used 2 or 3 pieces to get the thickness needed. When I get a chance will get you some picsHow were you able to access the back of the button to install the tape padding/shimming?
That would be great, thanksWhen I get a chance will get you some pics
I think if I read that another ten times and more thoroughly it might start to make sense but I guess my rationale is, whether it's the carb, the oil tank, whatever part/component, when the temperature gets cold that part is getting cold and is making it hard to start. So I figured if that part(s) can be identified and those warmers placed on it/them, then we've eliminated the temperature causing issues.Make sense?
There is a simple enough solution, heated garage... no need to place heating pads anywhere on the bike if it's environment is warm..I think if I read that another ten times and more thoroughly it might start to make sense but I guess my rationale is, whether it's the carb, the oil tank, whatever part/component, when the temperature gets cold that part is getting cold and is making it hard to start. So I figured if that part(s) can be identified and those warmers placed on it/them, then we've eliminated the temperature causing issues.
A heated garage is going to cost more than the $2k EFI conversion kit.There is a simple enough solution, heated garage... no need to place heating pads anywhere on the bike if it's environment is warm..
Now there is a great idea...This seems work on Ford Transit....
ApplicationsTo add: one thing I noticed is if it's cold, like 30s, but not Arctic, like single digits, if I give it too much gas or gas/air ratio then it also won't start but it's a different "feel" to the not starting. So then I need to back off more and it'll start.
To summarize there's 4 variables affecting cold weather starting with a carb;
a) clean starter button contact
b) amount of pre-start gas (throttle twists)
c) amount of enricher (gas/air ratio)
d) oil weight
an EFI would solve b) and c)
but as far as d) goes, who uses a lighter weight oil in the winter and if so, what brand and weight are you using?
The link shows different lighter weight car oils.
I don't know....The link shows different lighter weight car oils.
Would love to use the Motul but
I was told to only use the V-Twin formulated oil since it has certain ingredients designed specifically for V-Twin engines and not to use car oil.
Any truth to that?
"The engine and transmission of most motorcycles use the same oil supply, so motorcycle engine oil lacks car oil's friction modifiers, which can make the clutch slip. Amsoil Synthetic V-Twin oil is formulated for high-temperature, air-cooled engines and the demands of frequent, short rides."The link shows different lighter weight car oils.
Any truth to that?
