No H2O
Yes, it does attempt to crank so it's chugging but nothing is "catching" aka the engine not turning overSounds like they are...so it just cranks but wont start?
whole different ballgame, is the starter spinning the engine ?Yes, it does attempt to crank so it's chugging but nothing is "catching" aka the engine not turning over
So the engine is NOT turning over? Like he said whole dif ballgame. You been getting advice on an engine that spins but not starting. Sounds like your battery not strong enough. No matter how cold it is mine will spin the hell out itYes, it does attempt to crank so it's chugging but nothing is "catching" aka the engine not turning over
hang in there, we will get this thing running ....So the engine is NOT turning over? Like he said whole dif ballgame. You been getting advice on an engine that spins but not starting. Sounds like your battery not strong enough. No matter how cold it is mine will spin the hell out it
Battery bought new in August.I would put a meter on the battery, check the battery connections and make sure they are tight. The cold temps are hard on a battery and if it is not in tip top shape it will zap all the juice from it in a hurry. Somebody correct me if I am wrong we are looking for at least 12.8 resting voltage correct?
not meaning to sound too much like a dick, but maybe the best solution to your situation would be to go back to riding your BMW on cold days.Battery bought new in August.
Measures 12.75 at rest.
Even after a hair dryer for a while the engine is still bone cold. Right now things point to a matter of getting that engine warm before trying to start and tbh this is more and more leading me towards the EFI direction. It's not uncommon for me to work a 12-16 hour shift with the bike out front of the building in the cold. It's not like I have a source of electricity to heat the engine before starting, nor do I care to do so.
I guess the question now becomes since 08 was the first year of the EFIs, were those EFIs produced by BDM and therefore should wait for a later year or were the EFI's produced by another company who'd been putting them out for a while?
That's what I'm (unfortunately) doing but at the same time I bought a bike to ride when I want to ride, not to be limited to 6 months out of the year.not meaning to sound too much like a dick, but maybe the best solution to your situation would be to go back to riding your BMW on cold days.
Is it really noticeable? does it work well?If your carb'ed bike is not turning over why do you think that EFI'ed one will?
Recently I have started using my own timing curve in my adjustable thunderheart ignition.
I have retarded timing from fifteen degrees to nine degrees at zero rpm and rising to fifteen degrees
in a straight line at seven hundred and sixty eight rpm. This should make it easier for the starter
to turn the motor over. I would try this if you have programmable ignition in you're bike plus
I would get that lithium jump starter as well.
My two bob's worth.
Paul.
Simply because my FI fat boy is an 01 which is the first year that the fat boy had FI and in cold temps it turns over immediately and no throttling required to keep it idling so I can gear up while the bike warms. No blankets, no heaters, no enrichers, and no throttlling.If your carb'ed bike is not turning over why do you think that EFI'ed one will?
How many miles on your 01.just curious.Simply because my FI fat boy is an 01 which is the first year that the fat boy had FI and in cold temps it turns over immediately and no throttling required to keep it idling so I can gear up while the bike warms. No blankets, no heaters, no enrichers, and no throttlling.
If an FI can perform like that in 01 I figure an 08 BDM FI should perform like that as well, unless BDM made their own EFI in house then 08 would be the first year and I'd obviously want to research how those performed.
As a matter of fact I'd recently changed to E3 plugs.What do you think of expanding the gap of the plugs?
