Help electrical issue
2008 K9 with original ehc. Bike only starts when i use the slam switch. When i press the run/start switch just hear the CR's but starter does not engage. Checked voltage at green wire and reads 8 volts and stays at 8 even with start switch pressed. Has a newer battery and i do have an extra stop/start switch but replaced the current one a couple years ago. One other odd thing it did was yesterday turned the key and had nothing then the hazard lights came on. Eventually after turning key off and on the gauge and headlight came on but still no start with switch. Do I need to get ehc tested?
May want to check your hand control switch it could also be a shorted wire which could cause the hazard light issue.
Also may want to check the headlight harness, I had similar issues and I found mine had melted.
Fitzy
Exact same thing happened to mine and I changed the right hand control board stop ,start switch and it fixed the problem worth a go easy fix
