wildbill7638
I’ve been using one of them for years
In my area Aug. 17,18 & 19 Huge parking lot sale the lift is $284.99 I wonder if you can use the 20% off coupon with the sale, now that would be a deal.
My brother has one and it works great. would definitely recommend itI’ve been using one of them for years
The 20% off coupon excludes these parking lot sales which is what this weekends sale is. So anything in that email is exempt. Still this is a few bucks cheaper than the $299 Coupon, and this is the price I saw for their last parking lot sale.
Thanks for the tip! I just got the air compressor but I have not hooked it up yet.The trick to HFT lifts and Jack's is swapping the ram fluid out. The factory stuff is garbage. Same with the compressors, good product, garbage fluid. Swapped out my motorcycle fork lift's jack fluid for Sta-Lube Hydraulic and Jack Lift fluid by CRC, and have had zero issues even after months under load, buddy ran same bottle jack on his cherry picker, popped the seals and fluid bled out because the seals went, barely used the thing. Looks like same/similar jack/ram for the lift. Just drain the factory fluid and refill with a quality one, might not make it perfect or 100% bullet proof but certainly worth the $5-10 for the peace of mind and longevity. Same with the little $148 29 gallon compressor. Run it until it's nice and warm, drain every possible drop of the Chinese goat piss they use for lube out of it, throw in some Magnum synthetic compressor oil and it'll run like a champ and smooth. The regulator switch is super easy to adjust on it as well. Just my 2 cents.
Sent from my SM-G930P using Tapatalk
I have had that compressor for about 8 years now, put good oil in it when I got it and I've never had one problem with it.Thanks for the tip! I just got the air compressor but I have not hooked it up yet.
I got it for Christmas and I still have not set it up! LolI have had that compressor for about 8 years now, put good oil in it when I got it and I've never had one problem with it.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Yes, I’ve never had one so I’m waiting for Santa to show up and set it up for me !Wow brother...what are you waiting for? Christmas lol
The little compressors are pretty reliable when maintained properly. You'll still have to do a couple "heat and drain" runs to help it break in properly (there are directions floating around on the cycle times / hours and oil changes for break-in) but once it's in a happy place, like I said before, fresh, quality synthetic compressor lube will carry it well. I sold my little guy (HFT) and kept my DeVilbiss 60 Gal, use the same lube (Magnum) and it runs like a champ. I ran it hard using an air hammer to bust up tile a couple weeks ago, even under hard duty cycles the cylinders held consistent temps (check via laser gun) in a hot FL garage. So, my opinion only, well worth the couple bucks. If the little guy keeps cycling too much, once the warranty is expired, it is easy to reset the regulator min and max pressure cycles. Its under a small cover on the side, two (?) Screws, with nothing but a bead of cheap hot glue keeping them set. Tank is rated to hold a bit higher loads consistently. I reset mine to hold pressure longer and minimize duty cycles, increased the high end pressure settings and lowered the bottom settings. Have fun! I'm trying to get my hands on a lift ASAP. Devil is in the details!Thanks for the tip! I just got the air compressor but I have not hooked it up yet.
