turbo charger for s&s 107
Blac94cobra
I would really like to turbo charge the s&s 107 on my chopper (2004) but am not having any luck finding one. I talked to trask in phoenix and they said their kits don't work on the evo motors.
I've seen that bike in person. I can't find the picture I have of it, but the frame is beefed up and gusseted a lot more to hold it together. Plus if you look at Marc's picture, there using a RHD transmission from an 04 Bull Dog. Which is different than any other 04.
Big Dog set that bike up,(the one in the picture) to set a land speed record. I don't remember how that went, but the difference between that bike and the one I have a picture of, besides the frame, is when I saw it, it had a melded engine. It couldn't handle the heat.
Blac94cobra
during my trip through Sturgis, Yellowstone, etc last year I ran into a number of bikes that were turbo charged. they were not using for racing, but mostly touring. although I did see a few in Sturgis that were turbo charged and had nitrous. but I think that was much for show as go. the main reason I would like to do it is a) for show (and the sound) and two it should give the bike a bit more get up and go when you twist the throttle.. I am too old for drag racing ( I did race a 750 Kaw back in the day - the old triple two cycle one). I am hoping that after my chemo finishes in july that I can go for another long ride - thinking about going from here (Tucson) up into new England and then along the east coast to Florida and then back along the gulf coast and I think a turbo charged bike would be just the ticket. I will see if I can track down this guy and get some pointers
dentdude36
Banned
Dude!
http://www.bigdogbiker.com/forums/introductions.2/
Mallito
The only worries with turbo is having low compression but with the engine stock it will be low to no boost and only wise noise.
Blac94cobra
I am not sure I follow. generally a turbo works well on lower compression engines. admittedly this only has two cylinders and a single carb so the boost will not be too great which is ok with me.
Mallito
Yea but I'm not sure what compression ratio is the pistons , like 10 to 1 or 11.1 or 9to1 turbos like low compression and I'm not sure about a 107 but I have a 117 in my 06 ridgeback and have compression release so I'm assuming high compression
Blac94cobra
I just looked in the manual but unfortunately they give a lot of specs but not the compression ratios. they give the formula for calculating it but don't give enough info to use them. I will drop them a line and see if I can get an answer for some of the stock engines.
SEAL-rider
Compression is 9.6:1.
What have you already done to the engine? Cam, intake, exhaust, programmable ignition?
