Fork Dust Cap Removal
roadie1389
Did a search and I did not find an answer but what tool do you find works the best (or setup) for removing the fork dust caps? The last time I rebuilt them I put anti-sieze on it (just a little) and they seem to not want to come off.
Thanks
Soak them down with penatrating oil, use a rubber hammer and tap on them awhile. Strap wrench seems to work good to get them off.
Once you're done, make sure the threads are good and clean, and each time you wash your bike, unscrew them and blow the water out.
1mndg
RIDE IT HARD!!!
I use a rubber strap wrench.
Make sure your rubber o ring is good on the cap to prevent water from getting in.
Also some have a small relief cut in the back to drain the water out if any gets in.
