Anybody got a Starter!
flcmcya
Just busted my second jackshaft in a few months....wondering if the internals are out of alignment.....
20005 Bulldog.
bigkelk9
Happened to me twice as well.. ur best bet is to just drop the money and get the new updates one from Donna and Derrick. I got one.. phenomenal starter!
bdm7250
Check your compression releases if they are not working properly or weak is really the only way your gonna bust starters even with higher compression hence the meaning of compression release Donna and Derek have new ones they are your best bet , better go new than rebuilt the motor shouldn't ever hesitate or stop turning over abruptly if CR s are working and strong
And if you are going to change your CR's let me know and I will send you the special tool to borrow..
20005 Bulldog.
Unlikely can't get out of line.
Other than CR also make sure your starter gear and ring gear in the primary don't have chips taken out! I've seen them crack and chip and then the starter doesn't release cleanly. That will break the shaft, it's made from hardened steel so once it cracks even a little it breaks completely.
pknowles
RETIRED
Your more patient than me I'd be demanding the tins back finished yesterday and final payment after thorough inspection then drag the payment out 6 months 2 can play that game:)
Unless you really know the vendor, this is why you do a simple contract agreement with everything spelled out as plain as you can make it. Also after the supposed delivery date you need to assess LD'S
bdm7250
Sue is more pissed than I am, I need to exercise extreme patience for my job...guess it flows over into my everyday life, downfall of mine. :whistle:
pknowles
RETIRED
Hey, that might look spiffy...:willynilly: :oldlaugh:
No problem Doug, just tryin to help a brother. It a Mercury tank so it's red ,like the fender...---...
Just for your information, we have some 55 gallon drums that are red and we could probably cut out a rear fender:D How kool would that be:oops:
Patience is the name of the game. No point in getting panties in a bunch over spilt milk. There's a lot more important things in life thats for sure! I'm sure Sue can't argue with that statement
bdm7250
Then it would look like an OCC theme bike... :willynilly: :flush: :oldlaugh:
bdm7250
Well said my friend..:old2:
