So basically just pull the old up and out and push the new one on? Will it click in or just sit on the valve? The existing seems in there pretty snug, although I haven’t really yanked it.Get the KY off the head board, put a finger full around the inside of the new cup and push it in place. May have to use an angled pick to help push it down.
Wouldn’t the ky break down the rubber ?? LolGet the KY off the head board, put a finger full around the inside of the new cup and push it in place. May have to use an angled pick to help push it down.
It drys up quickly once it gets hotWouldn’t the ky break down the rubber ?? Lol
I would seriously consider using silicone spray over petroleum
So when using KY, take it slow and easy... Don't build up any friction..It drys up quickly once it gets hot
Man, you weren’t lyin! Took the rear cap off the soloniod but needed wd40 to get it to release. It seemed pretty slick so I used that to install the new. Took a while to get it to set around but once I did and worked it about 1/2 way down it locked up. Went to the front and grabbed some lube (astroglide) and once it set around the solonoid it basically spun all the way down quickly. Pulled the back one off again and reset with lube and all good! Thank you!Get the KY off the head board, put a finger full around the inside of the new cup and push it in place. May have to use an angled pick to help push it down.
I'm basically a lazy person, if there is a short cut or an easy way to do something, I've figured it out.Man, you weren’t lyin! Took the rear cap off the soloniod but needed wd40 to get it to release. It seemed pretty slick so I used that to install the new. Took a while to get it to set around but once I did and worked it about 1/2 way down it locked up. Went to the front and grabbed some lube (astroglide) and once it set around the solonoid it basically spun all the way down quickly. Pulled the back one off again and reset with lube and all good! Thank you! View attachment 55900
A lazy man is the best inventor..I'm basically a lazy person, if there is a short cut or an easy way to do something, I've figured it out.
I'm pretty sure I've got you beat in the Lazy Person category since most of what I've been doing is reading everything you do. I'm both amazed and tired after!I'm basically a lazy person, if there is a short cut or an easy way to do something, I've figured it out.
