SEAL-rider
2005 Chopper - lately when starting I am getting a kind of whine. Now that whine includes a vibration. It starts but does not sound good doing it. Ideas appreciated.
Oops - it was private. Fixed. Could that be pressure release valves or a battery that is not generating enough amps?Video unavailable
I would think its time to pull the starter.
Sounds like its engaging okay actually no click click click...Dragging big time.
You will sling oil all over the place unless you somehow cover it...ask me how I know. Second thought, dont! haI would take off the primary cover and hit starter and see if you see anything (maybe removing plug wires/plugs so bike doesn't start??
I would then remove the starter shaft and see if the whine is gone
- if it is not - then you know its internal to starter
Yes, it slung oil all over. Even after I dried the bottom of the primary. However the whine was gone. So, I need to find out if the primary case was already like this from previous breakage or if this is new. I suspect it is new wear. If so, and everything seems tight, why would the clutch assembly have moved forward. I did not find any metal shavings in the primary. The clutch seems to still work, at least it moves in and out. Also the bolts done seem worn.You will sling oil all over the place unless you somehow cover it...ask me how I know. Second thought, dont! ha
On your second point of removing the shaft how you gonna do that an start bike? LOL
Regardless I am with you, not sure its necessary the start.
I am confused. If this is a new condition then something moved. How is a shim going to help? I am asking not questioning the recommendation. ThanksThere is a shim kit I believe that prevents this if it happens I'll post the part number for you if I find it in my paperwork
Whatever this was, it just went away after I did nothing more than open the primary. Could it be the starter pinion shaft was sticking.Here is a video with sound.
