SomeTexan
From what I’ve been seeing, these Big inch twins start dropping power like a brick when they start losing compression. Just a little less than the stock epa spec compression will drop considerable efficiency. Its a lot of fuel to ignite in a big cylinder, if there isn’t enough spark, compression or heat, power will degrade fast.I gotcha, didn’t think of it that way, his worn out engine was prolly only puttin out 50-60 hp
I would like to see a dyno sheet before I believe that one Broham, of coarse I did see it here on the internet
when ya put that kinda time into it
