bigkelk9
She only has about 14k now.. got her a little over two years ago with 3800..How many miles on your scoot Kel? The 585 will be an upgrade for me in the near future.
After actually getting in there with eric, it was a cake walk.. ur guy's scoots will be a lot easier because i have a different nose cone which houses my ignition.. added about 5 minutes of head scratching and 10 minutes of work to the initial jobHow many miles on your scoot Kel? The 585 will be an upgrade for me in the near future.
Thats kind of the game plan, the shop that i got my bike from gets about 150 off per cylinder using their name. So the deal is for it to be shipped directly to them from the shop that is doing the work. The local shop is going to powder coat the block. I have to send them my stash tube and my oil cooler so they can powder coat and diamond cut them to match as well..Have the shop ship them directly to Navada and that'll save you a few bucks.
So tell me, I haven't heard one positive thing about the 600 yet, what do u find better about it then the 585 that I think I'm going to go with.. last minute game changers?Honing the cylinders with a deck plate and a base fixture in my Sunnen 616.
From what I’ve been reading, the 585 is great if you aren’t upping compression. It has less overlap giving you more dynamic compression. Now, if you cut the cylinders down and run the 585 you may have pinging issues due to the lack of overlap. With the raised compression, the 600’s extra overlap brings the dynamic compression back to a safe level for pump gas, and makes use of the extra static compression with more lift/duration.So tell me, I haven't heard one positive thing about the 600 yet, what do u find better about it then the 585 that I think I'm going to go with.. last minute game changers?
There may be something there, I know shit but I remember few years back in AR when it was seriously hot, I rode a long day and have shaved cylinders and 585, I had to kill the engine with gear... bloody diesel K9.From what I’ve been reading, the 585 is great if you aren’t upping compression. It has less overlap giving you more dynamic compression. Now, if you cut the cylinders down and run the 585 you may have pinging issues due to the lack of overlap. With the raised compression, the 600’s extra overlap brings the dynamic compression back to a safe level for pump gas, and makes use of the extra static compression with more lift/duration.
....I said he would have to cut the cylinders if he wanted to go with a 600. Since he already boxed them up and never measured the deck height it's a little hard to cut them when he doesn't know by how much.My bike rocks. At a roll in first gear it will hike up the front wheel and carry it. It's insanely fast.
If you want any power out of these engines, you must cut the cylinders.
You're hearing from people that have no clue and understanding about how camshafts work with compression and other variables
Yep needs to cover those tappet holes...
Don't go with a 600 cam unless you shave the cylinders and your already past that point as you need to measure deck height.
Sent from my 2PS64 using Tapatalk[/b]
