well i was cleaning my bike today and when i got to the battery cover on the primary side it was loose,after further inspection i seen it was cracked,so i figured it was from vibration,so i pulled the seat off and took the cover off,to later find the horn nut backed off and was daggaling in there,also the wires pulled out of the horn,so further inspection i found that all the rubber wellnuts that hold everything together in there were all hand tight or totally loose,later i also found that the freakin ehc bolts on the bottom of the ehc were sheered off and pulled right out of the ehc,now thats just sitting in there without mounts,what the hell??? this bike is a 05 ridgeback and had 500miles when i bought it used,it ran fine then bigdog told me to get it serviced cause there records showed it never had the first service,so i brought it to my dealer a month ago with 580miles to get all recalls done and service done(i wont mention there name yet,wait to see if they make good for it) and the i was actully happy with there service,but less then 200miles later,i find this crap,so i called them and first they said there was a recall on those rubber nuts,then he says im outa warranty,then he says it had nothing to do with there work?? well hello stop making excuses here,so he said they were never in there only to put the new vr recall fuse in (which in my opinion is a shambo install with only 1 nut and bolt on it to hold it in place but anyway) so i said to him well i had a service done,he says yeah but we dont check bolts or anything like that,so he said bring it up to him and he will see if bd will cover it or he said i will have to,i said yeah sure, now i just looked in my manual and it shows what should be done on the first 500 miles service and it states "CHECK ALL ELECTRONICS AND SWITCHES" ALSO "CHECKED ALL BOLTS EXCEPT FOR THE HEAD BOLTS" go figure....i mean are they trying to screw me? what do you guys think? any help is appreciated,ill be dropping it off tommorow..thanks jim
