BubbleHead
Big Dog Biker test account
I shut my 07 Chopper off to get gas. When I started it back up, I hit the starter button ( after letting it intialize) and the starter dragged for a second and then there was this very loud metallic bang from the left side starter area. I shut it down, turned the key back on, intialized it, hit the run start button and it started fine. no problem. As I took off the speedo needle didn't work anymore. The tach worked fine as well as the indicator lights. Then I rode for a distance, stopped, shut it down, started it all over again and every thing works fine. The speedo, no more bang. Any ideas what might have caused this? By the way, this is the second time this has happened in the year I have owned it since it was brand new.
bigbluedog and all the rest. this has been happening to me more and more lately, at least the bang, and what it seems like it is coming down to is a weak battery. sounds hard to believe, but it happens when i have stopped after short rides like between work and someplace for lunch or gas station and the bike has not had enough time to build the battery back up to get it over the compression stroke. it almost seems like the compression is throwing the rotation backwards and slamming the bendix of the starter. yes, when i am not on the bike the tender is but not when i am at work. the battery is almost (2) years old and probably time to replace it with a better one. any thoughts on this possibility???????? :2thumbs:
