Need help with air cleaner
RC18
That's a clean ride! I really like ur front foot pegs, who makes em and do they have matching toe pegs that you know of by chance?
I need to drill/tap them so I can get 'em sitting right with set screws
bigkelk9
Right one.. well as soon as them damn roulette pegs come in one of these months, I'll go with those, very similar.. cheers broham
They looked a little over center, you could use a layer or 2 of double sided tape. Cut right you won't even see it
RC18
Done that...they just roll up like boogers and move upward. Tried little rubber adhesive backed bumpers too.
bdm7250
I put the same spike from BD PartsKingpin on my bike. Installed, test rode and had the same problem over a certain RPM. Should need nothing more than the bowl vent removed as indicated in the S&S tuning guide. After doing so....ran just like it did right before install.
BTW...I'm pointed forward.
:agree: Was just gonna say the same. Good call.:old2:
What kind of pipes are you running ? Are they transmission mounted?
Your filter is different from a D&M Spike filter, the D&M is pointed on the end. I also removed the auxillary vent screw, made no difference on mine
RC18
The OP stated it was an air cleaner from Big Dog Parts Kingpin which is where mine came from (BDM engineered part). I believe that's the only spike air cleaner they sell. Someone else made reference to the D&M later but I don't believe that's what he has.
I wasn't sure which one he had. If he has the one you have, your the man to talk to. :oldthumbsup:
