I've beat my head against the wall all day long on this. 04 Chopper/ w 05 EHC. When I went to buy this thing, he said it fired up that morning. When I got there, it started and I took it for a test ride. Got ready to leave, it would fire. Checked it out and found it had no spark. The next morning, he called and said it started, got there, it wouldn't start. This weekend, he called and said it started, got there it wouldn't start. Got it home, it fired up, and I took it for a ride. Got back, went to put it on the rack, it wouldn't start.
Cleaned out the gas tank, and rebuilt the carb, and put fresh gas in it. It's not a fuel problem.
It started this morning, 8 times while I checked to see what all the lights on the EHC and ignition module were doing. Was going to take it for a ride, won't start, no spark.
I plugged another EHC in it, still no spark. I have power to the coil, and can manually load it, and it will spark. Even tried a different coil, still no spark.
I have power to the cam sensor, and it test ok with the Ohm meter. None of the lights on the EHC or ignition module do anything different, when I have spark, or when I don't.
The only thing I don't know how to test, or have an extra to try out is the ignition module. It's the smaller one with two plugs on it. does anyone know if there is a way to test it.
