Gmutoagrsv
Ok. Thanks. I just messaged them. I'll pull it apart in the morning and see if I can see anything.
Mine is getting stiffer. When it started it would click back if I pushed it forward. Now I have to actually push it. It's getting to the point where it's making my brake light stay on.I have bought the same levers last year and the same deal. The brake lever is a bit stiff like yours.
I just push it forward the last bit with my fingers after using it. It should wear in after a while.
After all I prefer a tight fit to loose rattly lever.
Paul.
That's so funny you posted that. I was looking at that earlier.
Glad ya got it fingered, I mean figured outUpdate. I pulled the perch apart and found where it was rubbing. I took the screw plunger out completely and no wiggles doesn't get stuck really smooth pull.
