He suspended his starter service last time I lookedIf that don't work you can also contact Curtis at wild steed works.
03 starter is out I changed the battery and checked the wiring .. it spins then clanking noise. It won't turn the engine over
Don't think its the solenoid if its spinningBefore you spend all that money, clean the contacts in the solenoid.
Like Shannon said, clean her up.. hopefully ur shaft didn't snap and that's not ur issue.. the clanking noise leads me to beleive something isn't engaging. But yeah I'd pull it off and clean it up first.. just had a buddy here last week go through that and he cleaned it up as per Shannon.. and he is back in businessI'm sure it's the bendix but I'd rather change out the whole starter if possible while I have the money it's an 03 so might as well
Check out ultima starters03 starter is out I changed the battery and checked the wiring .. it spins then clanking noise. It won't turn the engine over
How long does it take em to call you back ? Is this there only business or so they have jobs and do this on the side cause I been waiting all day for a call back?Call or text Donna or Derek 620-257-2009
I double checked the # and it is the correct one, maybe send them a text also, but usually they get back to you pretty quickWhich I'm not complaining just wondering if I got the wrong number?
