It's either the igntion module or the Cam sensor.No spark on the plugs, where else should I be looking
Should only have power to coil on Red wire not the Blue and Yellow. Unless engine is running.I checked the wiring coming from the cam sensor. There is no power coming out of the red wire. This was done without turning over the engine. The red light does not come on toggling off/run switch. However there is power to both coil terminals
Engine is not running only the ignition switch is on. Is my coil bad?
Good Job, Alexey.Hey. Start with the intro. And check the camshaft sensor.
