Explain adjusted the shifter to fit your feel? What did you adjust?YES to all of the above. I rode it before i bought it and it was OK. I did a little cleaning,
adjusted the clutch, adjusted the shifter to fit my feel, swapped plates and started to
ride and bAnG, NO shift. I might get into the trans cover today after church, I go to the
EARLY services![]()
You asked about the rod, I asked what he adjusted, maybe he adjusted the shift leverKinda what I already asked
Sure does, the million dollar question is whether he adjusted the rod or the shift lever on the spline.It does sound like he has something out of adjustment.
Why not? If you want to change the position of your shift lever, then you adjust the linkage rod length, correct?Did you adjust the shift rod? If so that's the problem never adjust the rod
It sounds like he adjusted the linkage rod to me.Sure does, the million dollar question is whether he adjusted the rod or the shift lever on the spline.
That's what I've been saying since my first post it's out of adjustment
All good...OK GUY'S FEEL FREE TO RIDE MY ASS FROM HERE ON OUT !!
I never thought anyone would make something you can't adjust.
IT WAS the shifter pedal down too far. I feel like a Harley owner today!
Thanks for all the ideas and help!
Bullets are on sale today for 5 cents each
Ron
