I did! Ruined it! This was before.Have you been polishing?...![]()
Yep that and the clutch cable will be removed and relubedDon't forget the air filter with all that sand flying around.
Visegrips? Shame on you..I did! Ruined it! This was before.
Well it was shiny...I did! Ruined it! This was before.
Think I used those with the welder to hold the nut and washer. That was when I was making the baffles.Visegrips? Shame on you..![]()
Makes sense, just seeing visegrips on a lift raises red flags for me..like the dudes at the local Harley shop..Think I used those with the welder to hold the nut and washer. That was when I was making the baffles.
Best way to polish aluminum is to get someone else to do it! Best Aluminum polish -- whatever their using!What's the best way to polish aluminum? And what's the best aluminum polish? And what's the best way to polish the engine with all the fins? Any advice and tip would would be very appreciated!! Thanks Vin cent![]()
I hear dentdude is pretty good at polishing, and doesn't have much of a work schedule..Best way to polish aluminum is to get someone else to do it! Best Aluminum polish -- whatever their using!
is that chrome or severely polished al? I heard that polished al can be as bright as chrome just not sure how to get mine that bright3000 will knock crud down and help clean the aluminum a little rubbing compound then billet polish and it looks chrome I did alicias bike a few days ago
#88 dentdude36, Apr 3, 2017
There are several threads on it. I have been testing different ways to get it really shinny. Depending on how bad it is, sanding works really well. Start with 1000 grit if it's really bad, then work your way up to 3000 grit. If it's just stained and discolored, use 0000 steal wool, then 3000 grit paper. Then finish it off with mother's billet polish. The secret is, flannel cloth. Get rid of the micro fiber rags, they scratch.is that chrome or severely polished al? I heard that polished al can be as bright as chrome just not sure how to get mine that bright
http://www.bigdogbiker.com/threads/spring-cleaning-with-shannon.79678/is that chrome or severely polished al? I heard that polished al can be as bright as chrome just not sure how to get mine that bright
Ya, seen it...show off...
Go to Wallyworld and buy it by the yard, for less than $4.00 a yard. Then cut it up in squares and strips.Buffalo Industries (60235) 13" x 24" Flannel Dust Cloth, (Pack of 12) https://www.amazon.com/dp/B00N2HQQ3I/ref=cm_sw_r_cp_api_kFrmzbKYN1E9G
Just ordered these. Cotton flannel. 12 of them for $15 shipped. Didn't know microfiber scratched till Dent said something about it a few weeks back. Tried an old cotton shirt and sure as heck Mr. Blind You Sparkles was right.
Inherent problem about chrome...Mothers billet works well on aluminum, big fan of it. Any suggestions, tips on how to address the dreaded flaking chrome issues,that some of the dogs are prone to?
