Clock on crack
PROFLYER
SWOLE
I'll add to that, I remember changing cams in my first shovelhead and EVO a long time ago and my old man and I cut the push rods with bolt cutters and took them out, then installed the adjustable ones. If that thing is flat out seized up you might have to do that and see if you can order that rod from S&S (or Derek or Curtis). Might want to get one on the way anyway, I can't imagine they're too much as a single piece. A whole setup on amazon is $190 (https://www.amazon.com/Cycle-Quickee-Pushrod-Cover-106-6051/dp/B0031BFF3M) .
Take pics once you do figure it out and post up a tech thread so we have it once the next guy has this issue?
