Help me figure out my noise....
JDouce83
Hey guys.
So I've had a noise for coming from my 03 chopper for a while now. Not crazy loud, but almost sounds like a hollow knocking noise. It seems to be a lot worse one the bike is warmed up and riden for a while. The noise only happens when I accelerate in 4th gear so obviously I'm guessing it's transmission related. It doesn't make noise in any other gear other than fourth. I initially thought it was primary related until just recently I realized it was only happening in fourth which is my main cruising gear. Have you guys ran into this issue before??
The first thing I would do is check and see if the primary chain is adjusted right, then we'll go from there.
Also, I see you have the 03, which has the Mad Clown rims. This will be a long shot, but lets make sure, check your belt sprocket for cracks.
It's a matter of torque applied. Noises will come for a assortment things. We're going to start with the easiest cheapest first, then go from there.
