PussyNot gonna touch that one...real tough though..![]()
Yes, at times..Pussy![]()
Ah was a bit tired yesterday, you mean balls in the ramp.Maybe different size balls?
That's what I meant was just a guess when they said "bearings" otherwise don't know what it could beAh was a bit tired yesterday, you mean balls in the ramp.
Having, not had the new one in my hand, i ordered one for a K9 I'm working on. I still don't know why it is tappered in the opposite direction than the ball rolls. It is ramped a little more in the direction the ball rolls, to the point that the ball doesn't] push the two ramp plates apart as far as the stock ones do. When i get this bike running, I'll let everyone know if i have any trouble adjusting it, or what i run in to.Looking at the pic, I wonder if you could just modify the ramp on the 12 plate clutch a bit. I guess I'm confused as to why the soft pull seems to have the tapered slots going both ways. Looks like they took the regular pull and then added slots the other direction. Is that what you were saying @Mr. Wright ?
I'm no engineer, but I also don't understand why the ramps go both ways. The clutch pull is only one direction. I could see the soft pull having a longer and shallower ramp compared to the stock (which is pretty abrupt) but then you're lengthening the overall distance you need to pull the lever--maybe that's why the adjustment is more fickle. The only way I can see making it truly easier to pull, while maintaining the same positive engagement, is to lengthen the torque arm of the plate--move the spot where the cable attaches further away from the pivot point. Obviously there are fitment issues there. I wonder if the handle side of the cable could be modified in the control?Having, not had the new one in my hand, i ordered one for a K9 I'm working on. I still don't know why it is tappered in the opposite direction than the ball rolls. It is ramped a little more in the direction the ball rolls, to the point that the ball doesn't] push the two ramp plates apart as far as the stock ones do. When i get this bike running, I'll let everyone know if i have any trouble adjusting it, or what i run in to.
If you modify the controls to make lever movement longer you might end up in the situation where you need to grow longer fingersI'm no engineer, but I also don't understand why the ramps go both ways. The clutch pull is only one direction. I could see the soft pull having a longer and shallower ramp compared to the stock (which is pretty abrupt) but then you're lengthening the overall distance you need to pull the lever--maybe that's why the adjustment is more fickle. The only way I can see making it truly easier to pull, while maintaining the same positive engagement, is to lengthen the torque arm of the plate--move the spot where the cable attaches further away from the pivot point. Obviously there are fitment issues there. I wonder if the handle side of the cable could be modified in the control?
