Fork/Steering Stops
PROFLYER
SWOLE
Guys, working on this 06 Mastiff I picked up this week. The fork/steering stops are non-existent. The damn bars turned hard when it was up on the underframe lift and hit the tank on the left side and took a dime sized piece of paint off :mad::mad::mad:
I pulled up the service manual and I'm thinking maybe the roll pins are broken off? I read through this thread: http://bigdogbiker.com/threads/fork-stops.15467/#post-223901 but it doesn't say what size the pins are. Anyone have a clue? Not sure if it's that, but they are what seem to 'stop' the triple each direction in the channels that are built into the bottom triple and the plate that sits on top of it. I'm going to rebuild the leaky forks once WSW gets me my rebuild kit and I'll address this then. Like to get parts ordered now if possible.
Thoughts? Thanks!
UPDATE FOR FUTURE REFERENCE:
Ok guys, got this fixed and turn stops again. I can't thank @Mr. Wright enough for his help!
I pulled the triple apart and discovered that I had two 6-32 cap screws sheared off of the bottom of the neck. The heads of the screws were still in the channel of the turn stop plate. That's the hard plate on top of the bottom triple that goes between the neck bearing and the triple.
Shannon suggested (Mr. Wright) that I get a hard LEFT HAND bit and try and work them out of there. I did so with quick success. That was the only quick success I realized for the rest of this project.
I wanted to go up in size, so I got some 8-32 set screws, drilled/tapped the two holes and put them in. They both quickly sheared off right at the bottom of the allen recess in the set screw--should have flipped them over and twisted them in with pliers (hindsight). So, I was back at drilling out set screws! Problem was I used RED loctite and they were a PITA this time. Got both out, went to re-tap both holes and in the left hole (as you're looking at it) the tap broke clean off. Awesome. Carbide is the only thing that'll break down a tap, or a torch. I have no torch. So, I fetched a ball tip Dremel and went to work. Shannon said we can fix the hole later, just get it out of there. After hours of grinding it out, I had a hole that was a pretty good mess. I used some JB Weld and left it overnight.
Come back to the next night, I also went and fetched some #26 and #21 cobalt and Nitro drill bits, some tap oil, a fresh 10-32 tap, some 10-32 x 5/8" grade 8 set screws, a few 3/16 Nitro bits and some 3/16 x 5/8" hardened dowel pins. First plan was to use set screws, if that won't suffice or I can't tap then just drill it out and use dowel pins (which still fit in the channel of the neck plate). I drilled into the neck where the JB Weld was and didn't feel good about the amount of metal I had there so we opted to flip the neck plate around (so the channel is in the front) and then mark/drill two new fresh 10-32 holes in the front of the neck.
That worked, but wow I can't tell you guys how HARD this neck is! It must be case hardened where the bearing races sit. I killed 3 cobalt #26 bits (wish I got a few smaller carbide bits for pilots) and then 5 (yes five) Nitro #21 bits. Finally after getting both holes deep enough I tapped them. Used a 10-32 tap, LOTS OF TAP MAGIC, and worked it in 2-half turns at a time, worked it back out, cleaned it, cleaned the hole, added more tap magic, went in again. I was NOT going to break another tap in the neck.
I then took the 10-32 set screws and screwed them in dry backwards (so the thin allen recess was way up in the neck). I dry fitted everything, then took it all back apart to RED loctite the allen screws AND the plate bolts. Guys, if you're ever in there check/red those plate bolts. Mine were really loose. Also they're a #25 TORX.
Got it all back together and bingo--I have turn stops again.
bdm7250
Thoughts? Thanks!
Pretty sure Mr. Wright would know this.
sorry, Pro, my manual doesn't give any kind of size for the roll pins (2). looked in the bill of materials and the installation instructions and it wasn't in either place.
Dragonslave
You have to take the triple tree off to see but its not very long. Only about 1/8 inch long. I think this happened to someone not that long ago and they had to weld another stop back up and grind it down.
PROFLYER
SWOLE
I don't have the frame tab though, do I? I'm so confused as to which frame is on which bike. I'm hoping I don't...or that means it's broke off which is obviously a no-fix issue. I suppose I can pull it apart and see if they fall out and then take them somewhere to match.
Dragonslave
Yeah either way you are going to have to take it apart and find out. If you have this sort of plate on the bottom of your triple tree you know to look for the tab on the frame because it has obviously broken off. It will be on the bottom side of the neck.
PROFLYER
SWOLE
Well hell...lets hope not. Manual shows the roll pins...who knows! I'll tear it apart and find out. Thanks guys.
Your are talking about the fork stops, honestly they are not needed but nice to have. I usually just throw a towel over my tank to keep the bars from hitting while doing maintenance. It does not effect the bike while operating
PROFLYER
SWOLE
I'm going to tear this apart soon. I'll post pics of what I find. I'm just praying I don't have the style where it has a frame tag that's now broken off. I look at it yesterday pretty hard with a light and I can't see where a frame tag would be. Fingers crossed it's a pin setup of some sort where I can replace the pin.
05chop
Memory tells me you have a tab on the cup about 1/2 long then small roll pins touch this tab.If you cant find roll pin try tap the hole then install long allen head screw.
PROFLYER
SWOLE
First of all I can't thank Shannon @Mr. Wright enough for his help. Such a wonderful group of guys here. Thanks buddy!
What a mess. I'm still not sure how I feel about the current 'fix' but we will see. So, I'm fairly certain this neck (being a bit different than most, odd) had two 6-32 allen cap screws in it. They were sheared off and rolling around in the channel of the plate on the bottom triple tree (see pics above). I'm not sure how they got sheared off, but I do know this guy dropped his bike 10+ years ago (right after he got it) and spent about 1200 on various parts--some of that being forks and such. I have a list and receipts. They would have to have left the triple together or else they would have seen them broken off. Who knows?
Anyway, I got a hard 1/8" bit LEFT HAND and slowly drilled both of the broken off bolts out. That went better than I thought. Then, I got an 8-32 tap and bit and drilled out both holes and tapped them. I got the right side tapped and then while tapping the left side the tap broke off. I got it bottomed out and then got about a creak out of it to back it back out and it broke off.
At this point, make sure living things aren't in the garage due to flying tools.
I texted Mr. Wright back and he said the only option really is to get a carbide bit of some sort and basically grind it out of there. He said not to worry too much about the hole as we can repair that later. So, I went to Lowes and got a Carbide dremel http://data:image/webp;base64,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 with a ball type end on it with a 1/8" shaft. I spent the better part of 3 hours or so slowly grinding that little punk out of there. I kept the hole integrity in check enough I think, so I was able to tap it again--but here's where I'm still on the fence about it. I think what I'll do instead is blow BOTH of these holes out to 10-24 and use 10-24 set screws (1/2' long, stick out about 1/4"). The 8-32 set screws are a bit puny and since the 6-32's broke...I'm thinking a 10-24 should be good to go. There is plenty of room in the neck for sure, it's about 7/16" wide (not quite a half inch).
So, it's still apart waiting on the fork rebuild kit today from WSW. I think I'll pull it back apart and tap them both out to 10-24. That neck is hard as hell too, and those titanium bits aren't worth a hoot. Carbide is the only thing that really makes a manageable dent in it and I have to say I'm impressed with that little Dremel bit (9905 Tungsten Carbide Cutter).
Instead of a 10-24 think of using 10-32, smaller thread root for the tap to cut, a little more on the material on the screw diameter and for additional strength you could grind a little off the top where the alan wrench hole is so you can have more solid material where the stops hit the screw. :2cents:
You could also install dowel pins if you have more than 1-1/2 of the length of the size pin for engagement..
bdm7250
:agree:
PROFLYER
SWOLE
10-32...didn't know that existed. Just saw 8-32 and 10-24 taps at Lowes. I'm going to go over to MSC Industrial and round up a carbide bit, tap and set screws to finish this up. I like the idea of them being a bit larger--the plate channel has room.
