When I bought my Ironhorse it was 6 years old and had 50 miles on it. Before I ever thought of firing it up I went through the entire bike, pulled off the primary and cleaned everything with parts cleaner, disassembled the trans and cleaned, removed the oil tank and cleaned any remenants out of it. May not have been necessary to the extent I went to, but I did find water in all areas, not a lot, but condensation buildup from over the years. I also removed all fuel lines to inspect them, all were in horrid shape, dry cracked, and would have leaked for sure. Rebuilt the carb, all o rings and diaphragm were dry cracked, and bowl was filled with crud. My long winded point being, just because my bike was "brand new" it was far from road ready condition. If purchasing a low mileage bike, do your due diligence and see what it looks like inside as sitting idle for years on end can be detrimental if not addressed..2006 K-9 with 25K miles, one thrust bearing later and runs like a champ. 2010 Bagger with 55 miles, long list of "storing issues" but runs like a champ now. And so far I've done 100% of the work myself. No doubt the best bikes ever made, and I am just about to add one more to the pund for other respons than riding it. I'm playing with the thought of getting a K-9/Ridgeback/Mastiff/Pittbull and build it for a lottery where 100% of the profits goes to veterans in need. Got some good connections for the lottery but need to find a bike for real cheap that can be rebuilt to be a one off I can advertise to the effect very few people wont know about it.
I agree totally, I bought my k9 from the original owner with 3200 miles on it and it was about 8yrs old.. a week after the coil went out and I looked at it and it was pretty corroded inside and out.. did a tear down on mine as well and rewired the bike and got rid of any future headaches by getting rid of the EHC and so on. Point being, the bike sat in a shop that the owner owned for all this time with minimal riding and I live in the salt air and it did a number.. so can always count on low milage, but I'm happy to say I don't have a problem child bdm!!When I bought my Ironhorse it was 6 years old and had 50 miles on it. Before I ever thought of firing it up I went through the entire bike, pulled off the primary and cleaned everything with parts cleaner, disassembled the trans and cleaned, removed the oil tank and cleaned any remenants out of it. May not have been necessary to the extent I went to, but I did find water in all areas, not a lot, but condensation buildup from over the years. I also removed all fuel lines to inspect them, all were in horrid shape, dry cracked, and would have leaked for sure. Rebuilt the carb, all o rings and diaphragm were dry cracked, and bowl was filled with crud. My long winded point being, just because my bike was "brand new" it was far from road ready condition. If purchasing a low mileage bike, do your due diligence and see what it looks like inside as sitting idle for years on end can be detrimental if not addressed..
I'm sure you came across similar "aging" issues on yours Kim, glad it's all taken care of. Just wanted to put it out there for others to keep in mind if purchasing older "brand new" bikes..![]()
True story, but I got rid of my Nova. Few years ago because I'd take it out on the weekend after having it sit for a week's and spring a leak or something would give and this was basically a new car.. got done with having to constantly dump money in her so when I got the k9 after years of research and a hard year of research prior to my purchase opted to avoid future headaches by getting rid of the brains of operation headache.. lol.. but yeah these are great machines and do require a lot of love!Bought my 09 Mastiff with 10,500 mi. from a dealer in Texas, first thing the battery was fried when it got here, then it blew a base gasket, then a head gasket due to improper torquing, then the VR burned up, then the dreaded electrical gremlins started, and installed a 585 cam at 14,000 mi, I have 20,000 on it now, and just recently had a hairline crack in my oil tank I had to have welded up, when I bought the bike I was fully aware that I'd be working on it, it's just part of owning a bike, in my opinion they are basically hot rods that need attention regularly.
Was it covered under warranty?2016 K9 with 12,378 miles adjusted the left hand mirror
Matt has been so good to work with I didn't have the balls to ask. I just sucked it up and tightened the bolts on the back myself.Was it covered under warranty?![]()
2006 Mastiff with 6,857 miles. Second owner, first one only put 1,230 miles on it, he said that it was too much bike for him. All Ive done to mine is tires, Plugs every 2500 miles, regular oil and filter change. Runs like a top. Love the ride Love the looks. Put old school and new school flames last winter. I did change out exhaust this year to stock as I think they look much better than the Vance & Hines. Which drug every time I turned right. Looked shitty at the tail end of the pipes. I'm 72 pushing 73 and I don't like to ride in the rain. Too hard to smile with rain hitting you full bore.Good to hear all the positive Big Dog experiencesView attachment 61386 2006 Mastiff with 6,857 miles. Second owner, first one only put 1,230 miles on it, he said that it was too much bike for him. All Ive done to mine is tires, Plugs every 2500 miles, regular oil and filter change. Runs like a top. Love the ride Love the looks. Put old school and new school flames last winter. I did change out exhaust this year to stock as I think they look much better than the Vance & Hines. Which drug every time I turned right. Looked shitty at the tail end of the pipes. I'm 72 pushing 73 and I don't like to ride in the rain. Too hard to smile with rain hitting you full bore.
34,000 miles now and that mirror is still good!!2016 K9 with 12,378 miles adjusted the left hand mirror
