BadDawg Bill
Nice to see someone has some common sense. It's a shame you have to do all this when these engines cost so much. My friend Curley Jim raced Harleys and they sent him engines that had your specs. You would think they would incorporate that in all their engines but then again they wouldn't make as much $$... Going bronze is a good choice because the needle bearings come apart and really screw up the motor.Bill, your absolutely right. I just was under the assumption that you might have been talking about the years from 04 to 08. Yes, I know many of friends that have older engines and they seems to have quite a few miles on them.
I am going to lay it all out in that thread I got going in "technical". But here is the short of it:
As mentioned, it is beyond belief that anyone could design something whereas you have two incompatible materials that ride on each other. I am setting up on the bridgeport to swipe .062 of material out of the rocker shaft housing, of which is made out of garbage cast aluminum. The material I am swiping out is going to be replaced by a bronze material wear washer, otherwise known as a "thrust bearing". When you have two incompatible materials that ride on each other, especially when it is in a "load" situation, you need to have either a needle thrust bearing or a bronze thrust bearing. A bronze thrust bearing is actually a washer. I set up on the lathe and made custom thrust bearings (bronze washers). In the industry there are many of offerings, although you have to be careful in the bronze of choice. If the wrong choice is made, it will wear away and not hold up to heat. These bearings that I made are good for 350-500 degrees and can handle a pretty good load. after complete, it will allow the rocker to go through it's lift motions seamlessly without noise and without wearing into the aluminum rocker housing.
After buying my dog my heart sunk finding out the engines and trans weren't built by the manufacturers. I only bought it because it had a S&S motor and a Baker trans... I could have built one for about the same with real parts. Little did I know I was scammed. That's why my first posts were so negative... Now I just feel sorry for the guys who have to deal with it and all the electric issues.... They are beautiful bikes but like beautiful women they take a lot of $$ to keep...
