RVH
OK, been reading previous post for about 4 hrs now and dont know any more than I did before I started except where certain components are located.....06 mastiff has been fine for the 1200 miles or so that I've put on it until day before yesterday. Went out to crank it and the battery was too weak to turn it over so I threw the charger on for a few hrs and it fired right up. Made several stops that day with no further issues..... Went to fire it up yesterday and same thing. Put it on the charger for about 30 mins and she fired right up. Rode to a local bike show for a few hrs and when I left, she fired right up. Rode down to the lake and stopped for about 15 mins and when I hit the starter she acted as though the battery was weak again. Finally got it fired up & made it home, cut it off and tried to crank it again immediately. As I hit the starter the battery acted weak again and I had smoke coming from either the starter area or the little module mounted under the battery box. Had other plans so I removed the battery and put it on charge overnite. Had a full charge this morning so I installed it, cut the switch on. After I hit the run button the EHC has a red light only lit. The ignition module has a red light lit. The little module under the battery has a red led that blinks continuously about every 5 secs. (alarm maybe?) I hit the start buttom for only 2 secs and same thing. Motor barely turns over and more smoke comes from the starter area. Still cant tell if its from the starter or the mass of wiring in front of the battery box. ....Could it be that the compression releases are not working and the starter is laboring? (only hit the start button for a second or 2) Sorry for the long post but wanted anyone who tries to help me to have the whole picture. Any advice will be appreciated.
Robert
Robert
