BD parts (OEM) on eBay today only, 4 Dec
bdm7250
TX is a big state... San Antonio is about 5 hrs drive haha. But I get your point.
Not 100 sure they will be onto the frame either FYI
I got the trans for the slammer, cause the stock 로드맵 전송 (roadmax transmission)http://roadmax.m.ec21.com/mobile/productDetail.jsp?productId=664808 I never trusted. Who in there right mind would put a Korean piece of shit behind a 124 motor..AIH would, so the Ultima is a direct replacement. If it doesn't bolt right up on the dog, should be close, both are 300 rear and quick measure looks like bolt pattern on the frames are at the very least real close. We'll see..:old2:
Well the ultima is made in Taiwan...pretty fucking close man
Ultima is far more common, tried and tested so to speak. Besides that's like sayin Canadians are pretty close to Americans :crazybitch:..:oldhardlaugh:
Haha... I'd run ultima products all day honestly. Can't beat it for the price. That's what I just put in for an oil pump on the dog and it was 40% cheaper than the SS pump. I just can't rationalize that for a hunk of aluminum and 4 tiny gears.
On the other hand you won't get any customer service from ultima unless you go through a Midwest dealer. Matter of fact I can't even find a rebuild kit for this oil pump which was kind of a Debbie Downer but I do believe a standard S&S oil pump gasket will work with this...i think
Next year when it grenades again then you'll be pissed:yesnod:
