That' the trouble with being great at anything.Painter for big dog back in the day but honestly no offense to him I know a couple guys locally that would put him to shame
For half the cost
there's always someone gunnin for the "top spot" !
What did you use to seal paint saver to tank?I got mine from JP Cycles
I just used the gasket that came with it, I had it repainted by BD and they epoxied it in and the paint still bubbled, I had the tank fixed for the 3rd time and I used 2 part epoxy that was supposed to be gas proof and that peeled right off after the gas fumes hit it. You can see some discoloration in the flake because the epoxy allowed it to get underneath. So I changed paint saver and cap to a different design and so far all is good. This one vents on top, you can see the vent hole, instead of venting under the cap like the OEM cap. I feel the OEM cap vents under the cap and then turns to liquid on the paint saver and wicks under the paint saver screwed in the tank causing the bubbling. The cap on this one vaporizes and evaporates the fumes before they turn to liquid. Others have not had a problem and this is my experience with my own tank and BD had 2 try's at it and both failed.What did you use to seal paint saver to tank?
No not a pop up, it screws into the paint savor.Is that a pop up cap, and what material did you use to seal gas saver to tank? Thank you, Mike Toz!
That looks pretty good..I just used the gasket that came with it, I had it repainted by BD and they epoxied it in and the paint still bubbled, I had the tank fixed for the 3rd time and I used 2 part epoxy that was supposed to be gas proof and that peeled right off after the gas fumes hit it. You can see some discoloration in the flake because the epoxy allowed it to get underneath. So I changed paint saver and cap to a different design and so far all is good. This one vents on top, you can see the vent hole, instead of venting under the cap like the OEM cap. I feel the OEM cap vents under the cap and then turns to liquid on the paint saver and wicks under the paint saver screwed in the tank causing the bubbling. The cap on this one vaporizes and evaporates the fumes before they turn to liquid. Others have not had a problem and this is my experience with my own tank and BD had 2 try's at it and both failed.
I bought this from JP Cycles and its the venting one.
This is really cool looking and I would love to have one but removing the original scares the hell outta me after seeing what some of you have went though, I think you know what I mean,![]()
J&P Part: 720-616
Ya don't know until ya try if it will come out.This is really cool looking and I would love to have one but removing the original scares the hell outta me after seeing what some of you have went though, I think you know what I mean,![]()
You know that old say'n, "Don't fix it if's it ain't broke" well..........Ya don't know until ya try if it will come out.
I'm with ya! And the stock caps are pretty durable.You know that old say'n, "Don't fix it if's it ain't broke" well..........![]()
To bad they don't vent properlyI'm with ya! And the stock caps are pretty durable.
Well there is always great talent available it's just that often times those people are not in the limelightThat' the trouble with being great at anything.there's always someone gunnin for the "top spot" !
